How long have you been scanning?
I was remembering my first scanning adventure. Actually I didn't have a scanner then, but I did have a multi-band receiver. It was a Wards Airline ten-band receiver.
It had various shortwave bands, AM and FM broadcast bands, and VHF Low, VHF Hi, and aircraft. Back in those days, that was all you really needed.
Most of the Nebraska public safety agencies used 39.90, 39.94, and 39.82 mHz; the state patrol used primarily 42.46 mHz. Of course, all of these agencies also used other frequencies that I don't remember. In order for the local police to talk to the state patrol, NSP had Plectron monitor receivers in the vehicles, and some of the dispatch offices for local authorities had a similar monitoring device, maybe even a crystal-controlled scanner of some type. The Plectron units were expensive, but they were made in Overton, NE. Now, most of the state and local agencies use a statewide P25 system, but not all.
slhbeard
Vicksburg, Ms
Around 1970. Started with tunable radio, then crystal, then programmable. Had Regency, Bearcat, Radio Shack, and now Uniden 536 and SDS 200. Worked Law Enforcement for 28 years. Police and Sheriff were on VHF Low Band. Then PD went to VHF Hi and used crystal scanner to read Sheriff. Then everybody went to 800 before eventually going to P25 700. Patrol vehicles used 4 channel , then 8 channel before going to current Motorola. Not sure how many channels now. Also had 23 channel CB Radios in vehicle. Lot of water under bridge since then.
barovelli
Monterey Bay, California
Since about 1974. Think I had that same radio. 5 bands on left and 5 more on the right with a slide switch in the middle. I'd been monitoring a few years before that, HF SWL on the Telefunken console and a few other multiband portables.
That Wards radio was the best - listened to CB, WWV, the somewhat overly friendly youth oriented Radio Moscow and other DX.
The VHF was what set me off to go further. I would hear Hams on 2m commuting to and from tech jobs in Silicon Valley. Local police & fire. Mobile phones. The CHP on low band. I upgraded to a Bearcat III so I could hear multiple channels hands free. Then got a Bearcat 210 when it's solder joints were barely cooled off. The '210 was the only scanner until the Radio Shack 2004 came out and I was gifted that one since most of my hobby money was paying for day care and diapers at the time.
Spent some time with a GRE PSR (??) for its SD card recorder and easy PC programming.
Digital encryption made me swap out the 2004 for a BC996P2. That one is still running on the bench, feeding a Broadcastify channel. Listening now is a SDS200, SDS100 and a Homepatrol2 in various
es93546
A Member Twice
Right Side of CA on maps
I started in the radio hobby in 1969 with a radio that didn't scan. It was a tunable handheld Radio Shack called the "Patrolman." The performance was poor as it received a wide range of frequencies no matter how careful you were trying to pinpoint something. The squealing was extremely annoying. I started to make a little money my first year of college so in 1970 I bought a Regency VHF High Band 8 channel crystal controlled scanner. The limited channel capacity and not getting VHF Low were limiting. A High Low model came out, but I didn't have the money to get one.
The next scanner was a 4 channel handheld Radio Shack scanner that had easy access to the crystals so I could crystal it up for use at work (Fire Prevention Technician -USFS-Kaibab NF). The entire eastern boundary of the Ranger District was part of the western boundary of the Coconino NF. Being able to hear them was productive.
I could not afford the BC-210 when it came out in 1976, but could when I transferred into a higher pay grad job. The BC-210 was my primary scanner from 1979 to the mid 80's when the BC-300 came along. From there I had a BC-100 handheld, which was my primary handheld until the GRE computer programable scanners came along around 2000. I prefer the GRE's as they seem quite intuitive. They were mainly handhelds. After the BC-300 took a dump, I bought the BC-780, which disappointed me with its slow tone search. From there my base station became the GRE PSR-600 and due to my rural/small town residence is working fine as my base station. There are two Type 2 systems in that I can receive from home, so I bought a BC325P2. I don't travel with it much as I find its operation to be overly complicated. I'm losing my cognitive functioning due to "injuries," which I won't elaborate about.
N6JPA
A Ham Radio Operator With too much frequency.
San Luis Obispo, CA
I was 8 years old. My brother had a CB base station and I had a Realisitic Patrolman radio. When he talked on the radio it would play on my radio. I thought that then I could talk to the Taylor, MI police. Of course, I didn't understand what was really going on. :)
D31245
FN42
For me, I started mid-1980's with a Regency HX-1500 (still have it) but stopped listening for many years. Recently took it up again a few years ago and use a Uniden BC125AT as my main scanner.
steve9570
Member WSAG-457 -KB1-KZW- KCP-2441 CB-WA1-BZG
Natick Ma
Similar experience for me, very lucky that my dad and uncle were ham radio operators so, they set me up early with tunable monitors, same here, police 39.XX and Fire 33.XX.
For swl I had the inner guts of a Zenith stand up piece of Furniture shortwave radio with 200 ft of wire, a used Lafayette he90 CB and a CLR 2 that my dad got the license for in 1965 as I was only 12.
Never stopped listening through Crystal's, programmables, trunking, digital and simulcast so this fall it will be 60 years.
nosoup4u
High Bridge, NJ
It was 1984-1985 and I learned DBase 3 and DBase 4 made a nice green screen page to work with.
I did the same thing around 1990, I had a nice DBase3 setup that I stored all my frequencies in. I still have the floppy disk, I have no idea if it still works. I tried to upgrade to DBase 4 but for some reason I had a hard time with it so I never did it.
BinaryMode
2600 dialtone blvd
Circa 1996.
Prior to that I was very fascinated with two-way radio since about 10 when I got some Archer Space Patrol "walkie talkies" for Christmas. Back in middle school I remember asking the campus monitor how far her two-way radio went. I kept talking about it with a friend who told me he had two-way radios which could have been CBs. It was during this time of 1993 I had gotten RadioShack kits for Christmas to build receivers which I took to Edwards Air Force base with my dad to watch the space shuttle land (remember the space shuttle?)
But it all really started in high school while in JROTC where we all had to do a class presentation on a subject of our choosing. My friends in class did their subject on Ham radio and I was interested. My friend let me check out his scanner during lunch and I tried to grab the campus monitor's two-way radios.
I could never find a decent job so I could buy a scanner. Then one day a friend called me asking if I wanted to help weed beet fields for money. I said sure! And during that hot summer I weeded beet fields as far as the eye could see and bought my first scanner at a pawn shop, a Uniden Bearcat 55 XLT.
Latter I got better scanners at RadioShack and took one to school programed to the wireless microphone frequencies thanks to the book Police Call and had it connected to a mini tape recorder kept in my locker. To this day somewhere in my mess I have tapes of the pep rallies.
Heck, I even have a mini cassette tape of when John Glen went into space for the second time thanks to a NASA simulcast on a local Ham repeater.
About 2002 brought P25 voice and trunking and all my scanners were practically null and void. Doing research at the library I found the frequencies at the FCC's website and entered those into my scanner. To my dismay only heard digital noise crap. So I knew something else was at play here. Went back to the library and did some more research and found out the system was P25. So then I began looking for a scanner that could decode that. It was the Uniden BC296D with the card I needed. So I took a job delivering phone books during the very cold late December early January to damn near every house in town and earned exactly the amount of money I needed for the BC296D. Since I was so familiar with how the P25 trunked system worked with all the reading I did prior to getting the scanner, I never really needed the manual and went to hand programming the scanner immediately. I was very impressed hearing digital audio for the first time. Long story short, I showed a police officer my digital capable scanner and he wasn't impressed. LOL! Probably was told or thought nothing like that had ever existed and thus thought he was unmonitorable.
Anyway...
K9KLC
Southwest, IL
Mid 60's with an old Setwart-Warner dial, and it just went from there. I was about 10 when I started more seriously listening to what I could hear on the the radio. Way too many to mention thru out the years. It's been a blast honestly and still is!
KC0QNB
Gothenburg, NE
Late 1970's for me. Parents moved us to a small town, and they were used to the city, CB radios, and related technology. They were amazed at the Plectron units local fire and police had, and one of them advised that a Realistic Pro-52 could be used to listen to local comms. (Still have that Pro-52 too). As programmable scanners were developed, we often ended up with a new one for the house.....I would tinker with the old ones.
Best time for me though was the early 1990's and a Pro-2006, when analog cell phones and cordless phones were everywhere. I still hoard radio technology, and monitor a lot. Great to hear what is going on in the surrounding area. However, for vacation...I now go where radio and cell phone signal non-existent.
One of the hams I know worked for Plectron until they closed up the factory the building is still there there was a engine rebuilder for a while now it is a collision repair center.
kc2asb
NYC Area
It's worth picking up a Plectron receiver if you have any analog systems of interest in your area. I have two that came from Ebay. One is on lowband, and the other is VHF-hi. There is very little left on lowband here in NJ - I used to turn it on during band openings hoping it would pick something up. By happy accident, the VHF-hi unit was on the frequency of an FD in the next county. I was amazed at the sensitivity just using the stock antenna - 18 miles away and full quieting. Is G&G Communications in NY still around? They repaired Plectrons and could re-chrystal them as well.
kc2asb
NYC Area
I started in the radio hobby in 1969 with a radio that didn't scan. It was a tunable handheld Radio Shack called the "Patrolman." The performance was poor as it received a wide range of frequencies no matter how careful you were trying to pinpoint something. .
The Patrolman handhelds were usually two-band radios. AM broadcast and either VHF-hi or VHF-lo. I think there was a model with the aircraft band as well. The larger Patrolman portables performed a bit better, but still did not approach the selectivity of a crystal scanner or monitor receiver.
KC0QNB
Gothenburg, NE
I only have an old GE monitor receiver that I picked up somewhere, and I had an old Metal Motorola speaker hooked up to it. If I remember, it was VHF Hi, it is in storage with all my other old radio stuff.
sonm10
Central MN Monitor
Sauk Centre, Minnesota
As a millennial, I'm probably one of the younger people here. I've been scanning the bands for the past 10 years. Started out interested to know what the lights and sirens were from the fire department. Eventually, I started searching the bands for other things to monitor. I love chasing trains and naturally have a scanner with. Spent a lot of time IDing stuff on the commercial bands. Another favorite is logging and tagging RIDs on the public safety system (ARMER) using UniTrunker. I kinda have been trying to get into listening to mediam wave AM radio, but been hit and miss there.
