I need to know how a dipole for VHF and a loop antenna for UHF are connected together in the indoor TV rabbit antennas?
/Ubbe
This formula is not much useful because loop in feet doesn't say whether it's the length of the wire or the diameter of the loop?
This loop is not also using a variable capacitor.
Ubbe
Stockholm, Sweden
Most loops doesn't use a capacitor. I have a loop that covers from 500Khz to 30MHz and doesn't use a variable capacitor.
It's always the length of the loop that are measured, not its diameter, as you can form it circular, square or a triangle, whatever you like.
/Ubbe
AK9R
Staff member
Super Moderator
Central Indiana
Whenever I've seen loop antennas being discussed, the relevant parameter is length of the wire. Since a loop antenna can be a circle, an oval, a square, a rectangle, a rhombus, a diamond, a triangle, etc., the "diameter" is not usually considered. If the loop antenna is built as a circle, the calculated length would be the circumference.
But why then on most loop antenna calculators, the number of turns are counted?
AK9R
Staff member
Super Moderator
Central Indiana
I'm not the antenna expert that some folks on here are, but I think that you add turns in order to make the antenna a manageable size when trying to receive the AM broadcast band (530-1700 kHz in the U.S.).
Using the calculator that you linked to, a single-turn loop antenna would have to be 40 or more feet in diameter in order to receive the AM broadcast band. At higher frequencies, such as the FM broadcast band (88-108 MHz in the U.S.), a single-turn loop antenna would be much smaller.
dlwtrunked
/Ubbe
Not a separate capacitor, but the capacitance of the loop itself is a factor and has to be included in any calculations even if indirectly. As we know, the resonance frequency is both the result of the that capacitance, from the loop itself and any added capacitor, and the inductance of the coil. And the statement the diameter is not relevant is false--as length, diameter, number of turns are dependent on each other, you can write the formula different ways; and the sensitivity of the loop depends on the area which is a function of the shape. Regarding the last statement, consider if you ran the the loop halfway one direction and then back next to itself. I worked with a physicist who was once employed to design antennas and would point this out often. A more complete formula is at VK3CPU Magnetic Loop Antenna Calculator
That's a magnetic loop antenna calc. I need a simple loop calc?
paulears
Lowestoft - UK
In one of your multiple topics you asked how a folded dipole could possibly work? Well a loop antenna is a sort of opened up folded dipole, but being a circle, polarisation is less critical. However - all these things have very low efficiency, so only work on string signals.
You also mentioned magnetic loop antennas, and these are MUCH more complicated to understand, and despite your comment about VHF, more applicable to HF operation. They tend to be multi turns of wire too - often ships would use these and they would be often rotatable, so they could swing and be directional. They tended to not have gain in a practical sense, but they were quite deaf at the sides, so you could take bearings.
