I've a number of V3 RTL-SDR dongles and also and Airspy one but I have also recently got my hands on the new V4 RTL-SDR dongle. I have followed the installation instructions that came with it and I have this successfully working with SDRSharp after replacing the rtlsdr.dll. (On x64 system you still need to use the x86 version of the driver with SDRSharp but other software such as DSD should apparently use the x64 version.)
DSDPlus's FMP24 will start up with the legacy rtlsdr.dll but does not work properly (e.g. you cannot change the gain from 0 .0 and it does not tune frequencies properly) but when you swap out the DLL file for the newer version then you get an error from FMP24 saying that the "Required file 'rtlsdr.dll' failed checksum test".
Presumably it should work if it was not failing the checksum verification. Is there any workaround or do we need to await an updated version of DSDPlus?
