mix-man
i use xcoder to record my scanner audio... is there away to record with xcoder and use shoutcast/icecast at the same time?
bravo14 said:DynDNS current IP is 192.168.0.1
1. I have changed the file name from localhost to my suwanneeriver29.selfip.net (nothing happening still says connecting I have my firewall/virus thing off.
I have question on blind 127.0.0.1 for icecast I wonder if I can change that to my ip.
It will work localhost:8000/live when I change that back to localhost in oddcast do I have to leave localhost server ip?
mix-man said:i use xcoder to record my scanner audio... is there away to record with xcoder and use shoutcast/icecast at the same time?
Tweekerbob said:There are many ways to skin this cat and I'll give you two:
1. Feed your audio into two different soundcards. Use one card for streaming, the other for recording.
2. Use a program like TotalRecorder. There are MANY MANY different programs out there similar to this one so use the one you want. You basically connect to your own stream, either locally or over your LAN and a program such as this will record whatever your media player is playing. With the proper soundcard it is possible to connect to your own feed locally while still streaming to the internet, all the while only providing Wave output to your speakers/computer/Recording program capable of recording wave out.
Ryan
Not my static ip, it is words...ffexpCP said:your ip is a set of numbers, no letters in it
You can use any port to stream your scanner - forward 8000 and see if Adelphia was telling you the truth. If they were, try some high port, like 38000 or 48000 (just to make it easy to remember - you can use any port between 1025 and 65535).NYRHKY94 said:So, in a nutshell, I'm looking for any tips, suggestions or help that the group may have for me in terms of how to get around the port blocking situation, if that's what my problem is.
If there's a router between your stream server and the internet (the usual situation), and the port you're using for the stream isn't forwarded by that router (also the usual situation), your stream won't be available from the internet.dave3825 said:Is there any way to stream a scanner over a network without using icast?
I want to stream my scanner at work over our network with out it hitting the internet
Al42 said:If there's a router between your stream server and the internet (the usual situation), and the port you're using for the stream isn't forwarded by that router (also the usual situation), your stream won't be available from the internet.
Exactly the problem NYRHKY94 is having - in your case it's not a problem, it's what you want.
