BCD325P2/BCD996P2: How to lock out (not scan) a trunk group
KAZ7ED
I got too used to the BCD436/536 SDS100/200 programming and scanning, and now have a brain fart on how to lock out an entire trunk system on a BCD996P2 while scanning.
hiegtx
Mentor
Dallas, TX
The easiest way would be to assign quick keys to the sites, and use that to toggle them off.
KAZ7ED
Quick keys on sites yes, but no quick keys on system(s)? I will try the F+l/o,l/o Thx
hiegtx
Mentor
Dallas, TX
ProScan does not offer the option to set a Quick Key for the system itself. And that's not an option on the scanner either (at least, on my 325P2, the portable sibling to the 996P2)
Note that FreeSCAN does allow you to set a System Quick key, but if you do that, it also resets all of the Site quick keys to whatever you entered at the System level.
You can set system quick keys on the database scanners (x36HP & SDS series), and different ones for the sites,
tvengr
Well Known Member
Baltimore County, MD
Here is a PDF file which will answer all of your questions about using quick keys:
  • Uniden Scanner Quick Key Instructions DMA.pdf
