Well said! Before I was a ham, I took a radio (Uniden 520 Pro XL) to get peaked & tuned, and wasted the money....didn't do anything at all.
Just to add a little extra here...remember a factor CB comes from the assembly line at about 70-80% of the FCC legal parameters, reason for this is to ensure all radios coming off the line are within legal limits...This is where most new CB'ers believe that a Peak and Tune will bring you modulation back up to 100% and your final adjusted for a 4W carrier. ***Most CB shops will exceed these limits to the point where components will fail prematurely, your radio will most likely leave the shop sounding loud and proud, but after a while of good road chewing you'll be left with a blown final and a fancy night light for your vehicle...Beware of Peak and Tunes...you can properly Peak and Tune your rig to maximize your legal limits just to correct any under adjustments from the factory but the difference will be nominal at best, unless you make the choice to cross over the line so ofter spoken here in this forum between CB'ers and Hams...A correct Peak and Tune would constitute upgrading finals and other components to handle what the radio was never intended to handle in the first place. I am not a Ham operator but I did stay at a Holiday Inn last night! Understand that Ham equipment was designed with higher quality components and intended to operate and great power ranges unlike our CB's...Most CB's will not be shipped from the factory with high quality finals and components because they were never intended to operate outside of 4w, so they can afford to utilized lesser quality components due to the FCC limits restricted to CB radio's. So I hope this helps you some what...I operate a "Barefoot" Cobra 29 LTD with a Wilson 5k antenna mounted center on my roof and have no issues talking to the big boys on the road or to friends in town. Best thing to do is read all you can about antenna's and how HF works and use that to figure out what equipment you want to get and how and were to place it for maximum performance.
