how to program my scanner in trunking mode
deb2433
iam new at this and bought a rs pro-162 triple trunking scanner and i have all the frequencies in under the 800 mhz for tacoma police and fire and its in the right mode just dont hear alot,i know there crime in tacoma,i guess iam not understanding how to use the id's and groupslist yet.dont laugh at me iam new at this need help plz
lowboy654
DB Admin Member
Northwest, WA
Stavro35
Bainbridge Island, WA
Ken
Because I don't drive,that's why. I don't know my way around here. Or I'd take the bus all over. I have my psr 500 programmed. It's been programmed for some time now.
Steve
DickH
Ken
Steve
You don't need to drive to take the ferry and there are free bus route maps or someone can meet you at the ferry and drive. You've been here for several years and you haven't figured that out yet?
deb2433
new ?
ok i have some of my tacoma 800mhz channels going so i think iam ok there the next ? is i bought the book with all of washington and org freg in it but by the names it say tg and a number.how you i make that freg,like it may say tg 56784 whats that.if i can figure that out i got it because i can get the freg in motrola mode plz help again.
AtomicTaco
Put each trunked system in a new bank. Program the control channel as Motorola, and then add the IDs to the ID bank. I can't give you exact steps since I've never used a Pro-162. Read the manual for instructions, and see the RadioReference Glossary for help.
Stavro35
Personal attacks and b.s
Cut the crap out. I didn't attack you. Don't you jump on me
deb2433
ok i do understand that so you mean like all the 800 numbers in there own bank or all just the 800"s in one bank,and in my ? i ask about the book of freg saying next to each police/fire etc it says tg and a number like tg 46944,i know tg means tag but i dont understand the numbers,my book that i got with the scanner says this is used in desamals so would it be 465.4400 ?. thank you so much for your help and sence iam new here i sure would like to make friends here
AtomicTaco
TG means talkgroup--not tag.
Using the King County system as an example, program 851.8125 in channel 100 and set as MOT. Then for ID bank 1, key in 36944 for the ID and "Auburn PD Pri" for the text tag. 36944 is a Talkgroup, abbeviated TG, sometimes as TGID. You might want to read this to brush up on the concepts of Motorola Type II trunking.
Deb, you might want to program the scanner via your computer. You have to buy the USB cable (from radio shack, stock#20-047) and then you can go here for software:
http://www.butel.nl/products/arc160/arc160.html
The software is a demo so you can test it out before you buy it. It really makes programming much easier.
-Nick
