BCD436HP/BCD536HP: How to scan favorites list
jpeckert
Scanning favorites list
Is there a way to scan just the favorites lists? I have 8 favorites list with either one conventional analog channel or one trunked talkgroup in each favorite list. When I power up the scanner there's a message on the display that states: Scan Mode : Nothing to scan
lamarrsy
Rimouski, PQ, Canada
Hi,
When your changes are completed in the software, before transferring the lists to the radio, you have to check mark the ones that you want to transfer and not forget to also check them as "active" to be scanned (or something similar, I don't have the software in front of me).
fxdscon
¯\_(ツ)_/¯
I've programmed my BCD436HP with eight different favorites list that include conventional analog frequencies and analog trunking talkgroups, and I want to only scan the selected favorites list. When I turn on the scanner there is a message - Scan Mode: Nothing to scan. Any ideas? Thanks, Jon
There was an answer posted to the same question you asked in the other thread you started in this same forum 3 days ago...
Check here:
http://forums.radioreference.com/uniden-owner-tech-support/299294-scanning-favorites-list.html
AC2OY
Belleville,New Jersey
I would bet a paycheck in the profile monitor and download were set off...I did a hundred times. It's a learning curve my friend don't worry in a little bit you be a pro at troubleshooting!!😀
Moose
New Jersey
And you'll earn the right to tell your friends that it's the easiest-to-program mobile professional scanner that you've ever used.
