For VHF systems, even conventional repeaters, there is normally no standard offset and the FCC doesn't require specifying frequency pairs for each repeater.
There could be 6 repeaters and the license will show 6 FB frequencies (outputs) and 6 MO and/or FX frequencies (inputs). Normally there is no way to tell which input is paired with which output. You might get lucky and find that the number order of the frequencies on the license matches if the person who filled out the application entered all the data in order.
Here is the license for the site you posted.
FCC Callsign WQPV891 (MISSOURI, STATE OF)
www.radioreference.com
MOSWIN uses a mix of public safety, paging, auctioned marine and federal frequencies depending on the site.
The paging and marine channels, which this site doesn't have, are paired so those are easy to figure out.
The only thing you can tell in this case is 151.34 is the input to 154.935.
The 163-172 MHz frequencies are federal. All you can tell from the license is 163-166 MHz FX1 and MO8 are inputs and 169-172 MHz FB8 are outputs. There is no way to tell how they are paired without direct monitoring.
