HP-1 Programming Question
W9AJM
Wisconsin
Thanks for everyone's past help on getting going with the HP-1 programming. Got the Sentinel software up and running and it reads the SIMM card. I deleted the old Favorites list and started making a new one, which I seem to be getting the hang of, of finding and entering the system I want and the individual talk groups. So far so good. I take the card in re-insert into the scanner. However, the scanner keeps reading the old favorites list that is no longer on the card. What is my next step so the scanner is reading off the card? Thanks in advance. Andy
hiegtx
Dallas, TX
'Clear user data' with the card inserted, then reprogram the card.
Alternatively, if you've cleared the "old" systems out of Sentinel, but they're back after you read the scanner into the software, then you'd need to choose the option (click the check box) to "Erase Favorites Lists on Scanner". That will clear all the lists that are on the memory card.
