HP-1 Question
Jimbnks
Central, KS
Not sure if this is the right place for this, I am newbie to the HP-1 and all of it's setting, , When I setting up new scan lists I ran across a setting that had system type P25 X2-TDMA as a option in my HP 1.
So what does them mean?
phask
zanesville
It's really not the correct place. HP1 will not receive p25 x2 - so just where did you see this exactly.
Jimbnks
Central, KS
In the Sential Software I was adding my private Conventional Radio channel. What I did was Edit Favorite, with Favorite name highlighted in the system tab I hit the plus sign It popped up create new system. and had the following systems to add.
Conventional
P-25 Standard
P25 X2-TDMA
P25 One Frequency
Motorola
EDACS
LTR
I have got Version 2.05
I hope that is helpful.
mikewazowski
Forums Manager
Oot and Aboot
Nope, not the right thread. I've moved your post to its own thread.
Jimbnks
Central, KS
Thanks Mike, Sorry for posting in the wrong place. I am a newbie user in here well.
rwier
Phoenix, AZ
Conventional
P-25 Standard
P25 X2-TDMA
P25 One Frequency
Motorola
EDACS
LTR
I confirm the above "P25 X2-TDMA" option. I have never seen that screen before, as I have never created a "System" from "scratch".
phask
zanesville
I have version 2.03 that is in the drop down. I know there was a newer release, but then I don't remember when.
Mine was installed / updated 7/14/2014.
Voyager
It means the system could use either P25 Phase II or X2 audio, but likely is using P25 Phase I.
Jimbnks
Central, KS
I have not had an update from Version 2.05 sense I done the initial install 10-4-14.
Where I live in Kansas there is no Phase 2 system around me that I am aware of to test it < Rice Co.>
However seems to work great on KSCIS network.
