I just opened my HP-1 and the supposed Super Cap at location marked BT-1 charges in all operating modes of the HP-1.
So... as long as the AC power adapter is plugged in, the BT-1 device sees charge voltage in mine even if I never select Yes for the charge icon on the touch screen. Or if I select No at the charge prompt regardless if the HP-1 is on or off, BT-1 gets charge voltage at all times the external wall wart is plugged into the radio.
It's odd that it's marked as "BT" when all the caps are properly marked with the letter C prefixing their number.
Either there was a design change and a battery was replaced with a small super cap or it really is a small rechargeable Lithium cell like the early model 536HPs had in them which always failed and caused the RTC recall. Those 536HP Lithium cells were replaced with a super cap but it's significantly larger than the thing marked BT-1 in the HP-1. In fact, the BT-1 item is the same size as the 536HP's rechargeable Lithium cell was before they replaced the entire front board with a super cap and proper LED's for the dimming problem.
I measured mine and it only showed just over 1 volt before I plugged it in for the charge test. When plugged in, it was slowly approaching 3.15 VDC but I didn't wait to see where it would stop charging.
Even with just 1 VDC on BT-1, my RTC was still holding time in my HP-1. I sometimes leave it unplugged for weeks on end and have never had to set the clock. I do check the clock now and then just to see how much it drifts but that's it.
I'm not going to unsolder BT-1 from the board and look for any part numbers but I may be doing that soon being as it only had 1 VDC showing on my DVM.
I had just had my HP-1 plugged in to power for about a week within the past two days or so. I think that's a sign my BT-1 may be failing regardless it it's a super cap or a tiny rechargeable lithium cell.
I also wonder what the two large Elna brand super caps are for that are mounted right next to each other laying flat on the PCB.
I lifted one and they are rated at 2.5 VDC 1 Farad (not microFarad!) so they are also a super caps. They are Elna Dynacap DZN series wired in series so each sees about 1.65 VDC across it and of course 3.3 VDC across the pair.
Possibly something to hold a setting through a AA cell battery change perhaps. These large super caps measure 0.320 inches in diameter and 0.915 inches in length. They are mounted to the PCB via thru holes on one end and then they folded them down to lay flat on the PCB and affixed them with some type of glue to hold them in place. They are located very close to BT-1.
I know Elna makes caps but I do wonder now if BT-1 is a tiny rechargeable Lithium cell like the early design 536HP's used or if it really is a small super cap.
I swear I can remember Paul (UPMan) saying the HP-1 did use a lithium cell for its RTC backup. I also seem to recall some HP-1 owners having similar RTC battery failures in their HP-1s but there was never much said about that.
My HP-1 is an early model bought not long after they became available and it's never been back for any service so it should be the original design.
I don't remember the exact quote, nor whether it was here on RR or elsewhere. Paul (Upman) stated that the RTC circuitry was the same on the HP1 as the 536 and he anticipated the same failures. FWIW - I have 2 HP1 and 1 HP2 that all exhibit the issue.
