Ht1250 Problem..
ff_emt121
I own a Motorola HT1250 vhf radio, and I've had some transmitting problem to our com center.I receive just fine, but when transmitting I've been told that sometimes I have a lot of static and unreadable. Other times, I'm clear but I just have low modulation. I'm told by some people that work @ com center that my modulation is low and that could be the problem. Is there anyway that can be fixed, or what?..... help. I want my radio to work well :"\
bezking
On the Road
Maybe you are just too far away from the repeater/base station to come in clearly... What kind of antenna do you have on the radio?
ff_emt121
I have the standard antenna that comes on the radio, not too sure what it is. The county in which I was talking to, has no repeater.
Other times, they've been able to hear me perfectly fine, it's just here recently things have got worse. Last night I was "clear" but "low modulation" before that it was just a lot of static, and they knew my voice so they knew who was calling.
bezking
On the Road
It sounds like something is wrong internally - I would have your department's radio tech or a local Authorized MSS examine it.
ramal121
Lots and lots of watts
Calif Whine Country
It's like the Toyota go fast problem. A lot of complaints on HT1250's VHF about bad transmit, but nobody can seem to resolve. Are these being used with a speaker mic?
securitymikey
New York
I had a HT1250 that had a similar issue. I sent it in and they changed the mic element inside the radio. After that it was fine. I am guessing your mic gain in the programming is set to the normal settings right? Also try using a speaker mic to see if it is something with the internal mic. Thats what I did before sending it back to M. The repair was around $70.00 back 5 years ago.
Gezelle007
Lurker in the Deep
Oregon
Wait how does your county not have a repeater? If you were on Simplex it might be that you are too far away?
