HT1250 Programming problem
nozzlenut83
Hudson Valley
I'm having an issue programming an HT1250. I am using Windows 7 Home Premium, a USB RIBless programming cable with the FTDI Chipset, and Professional Series CPS R06.12.09 with a valid license/subscription.
Using the same identical setup I have no issues reading and writing an HT750 and other HT1250s, however when I try to read the codeplug from this one HT1250 I get the following error:
"Couldn't open port.Check whether device/RIB are powered on or not, and the Device to RIB, and the RIB to PC connection is OK."
I am using the File ----> Read Device... sequence rather than to toolbar shortcut also.
I'm a little stumped, I have successfully programmed other radios with this setup and I'm not sure what the problem might be.
Any help or suggestions would be appreciated.
Thanks.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Thanks.
If you can connect to other HTs and successfully read and write, I'd have to suspect the contacts on the side of the radio in question as a first step. Give them a good cleaning and see if that solves the problem. Step #2 would be to check to see if the flex cable between the contacts and the radio circuit is properly connected or damaged.
nozzlenut83
Hudson Valley
Thanks Steve!
I found the problem. I purchased the radio used from someone who usually does nice work. However when he refurbed this unit he was sloppy with the escutcheon sticker over the universal connector. It was slightly off causing the cable to not make the proper connections.
I can't believe I missed that. Anyways, It's fixed now.
Thank you!
