HT1250 - Scan Question
SFD1117
Shelton, CT
I recently programmed my HT1250 and am experiencing trouble with the scan function. When I have the scan system feature ON, regardless of what channel I switch to, my Ch.1 always displays the name on the screen. When I have the scan system feature OFF the channel regular channel name appears. It seems the Ch.1 or priority channel always reverts when in scan mode. Any idea on what I am doing wrong programming wise? Thanks.
DPapay
Morris County, N.J.
Possibly, in the scan list, the first channel is set to "Personality 1", this makes the priority channel always ch 1.
Set the first ch to "Selected", this will make the selected channel the priority.
SD70MAC
NC
scan
Just a note make sure you did not take it out of the scan list. You have to go to your scan list but under the TX CONFIGURE tab you have to change that to <selected> . This is what makes the radio do this. If you done this under the LIST tab you took your channel out of scan. Just my 2 cents !
SFD1117
Shelton, CT
I appreciate your 2 cents! LoL Out of curiousity, I knwo your able to create more than one scan list. I have 4 scan lists. For some reason when I go into my menu and click scan list it beeps and does not let me view the otehr scan lists. Any idea why?
SD70MAC
NC
Without looking at the codeplug,I would say the USER PROGRAMABLE box is not checked in the first tab of the scan list page. This would not alow the user to edit those lists. I have had to do this to some HT1250 we have because some of the guys don't understand the radios they use and no matter how many times you teach them.
