tmahoney748
Branford
I’ve been trialing the newer talk permit tone feature on my APX6000. All parameters are met for this to work… and it works fine when scanning is off. When scan is on I get the “bonk” more often than not and I have to press the PTT a few times to get a channel grant. Is there something in CPS that I am missing that may cause this issue when the radio is scanning?
K2NEC
5F6
In your scan list, is it set to "selected channel" or "talkback"?
K2NEC
5F6
Sorry, at the time of posting I wasn't near a computer so I didn't have the exact phrasing.
What is your "Designated Voice Tx Member Type"?
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
I *think* Convemtional TPT needs specific packets to be received from a repeater before the conventional PTP is emitted.
I don't believe conventional TPT will function on a non repeated channel
tmahoney748
Branford
You are correct. My issue arises when the scan function is turned on. When the radio isn’t scanning the feature works perfectly fine.
mbnv992
Also known as MT2000 man on Batlabs since 2001+
AZ
Speaking of the TPT, I’m surprised the DVRS trick that works on the XTS5K series doesn’t work with the APX.
carlos7801
Lawrence MA
Not required for APX as it’s now released in the newest FW versions. FW 33… something I can’t remember exactly for ANs, and I believe after R30 or 31 they introduced it on conventional, and configurable on a per personality basis for P25 conventional
mbnv992
AZ
With the APX the TPT conventional is only though a repeater not simplex. The XTS DVRS was both conventional simplex and through a repeater
tmahoney748
Branford
Ok, mine is 2 seconds. maybe try that and see how it acts. One second may not be quite enough time for the radio to decode the info from the repeater. Just a guess though.
Didn’t work BUT (of course I’m away from my computer when I thought of this) maybe my priority channel look back time (something like that) is too short? It’s set to 550ms currently. I have better luck when my selected channel is the secondary priority channel. It may be looking back while it’s also waiting for data from the system.
tmahoney748
Branford
Update: had zero effect. 🤦‍♂️
Rlahey
Sunnyvale Trailer Park, Dartmouth, NS.
Late to the convo here, but the big issue with TPT is the REPEATER side, not so much the user. I cant confirm, but I suspect only Motorola Quantar style repeaters will send the correct data to enable the TPT on the end user side, AND the the repeaters have to have up to date firmware
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
Not sure what you mean by "Quantar style repeaters", but it works just fine on GTR8000's.
