Using the latest tuner (legal) reading the soft pots etc how long does it take? I am wondering as it read and writes fine in CPS however it's been a bit reading the tuning values just sitting at the screen. Your thoughts?
Edit: the window says the application is not responding. So what do you think? The radio shows normal channel operation so you think I'd be safe to turn it off and unplug? With the APX and XTS or others I never ran into this issue so pondering the wait out or unplug and risk a error.
Additional: I went ahead and took risk and just shut the radio off. Turned it on and it is fine and transmits at the same levels according to the equipment. I am guessing a best shot that for some reason the port did not get to the point of opening the radio when the tuner stopped responding. Could be several software issues within Windows but I would still like your thoughts and if you encountered these. Please no doom gloom I heard you can get a fail or eprom error. I know the possibilities but if you comment your actual outcome and if during a read fail the outcome and solution. As it stands it's tx/rx fine at proper levels just wondering your experience with it. If you wonder it is a Windows XP machine with last version and drivers for programming. Firmware on the hardware radio is last version. Lol I also went to open CPS and the pc is unable to get port names. Looks like a driver issue or port issue somewhere. Will investigate. Thanks for stopping by though.
