RC286
I am a newly licenced HAM (as of Oct 30th) VE4BDE.
I have been messing around with radios for a long time, mostly CB, SWL and scanning. I finnaly decided to stop procrastinating and went out and got my licence. Passed basic with honors, so I have access to HF.
Last year at the local amateur radio flea market, I picked up a pair of HTX-100 10m SSB/CW tranceivers for $80. One was suppised to work, while the other was supposed to not TX.After getting my antenna switches and tuner hooked up to my CLR-II (I still use the CB as I am also part of a local SSB dx group on 11m) I tune up the radio with CW, and go to try and make a call on SSB. No RF. After swaping the radios and microphones back and forth, I discover both radios put out RF on CW, but I was getting no power on SSB. I notice with one mic, I am getting very low modulation, and with the other, nothing. Last resort, I pull a mic open, and swap the transducer with one from one of my old CB mics. Lowe and behold, I have power output! So I am sure both radios work, the mics are just shot.
I have a Turner II I would like to wire up to this radio, but looking at the mic wiring, it seems that the PTT and microphone grounds are seperate, at least from the connector to the mic anyway. The turner II being wired for 4 pin, only has 4 wires, and the PTT and mic share the same ground.
Does this radio actually have isolated grounding for the PTT and microphone transducer, or is that just how it is wired from the cassis to the mic.
I ask, because I would like to build a a switchable interface to switch between my turner II 4pin mic and tranformer isolated line in and out (as i read online the mic connector has an audio line out on it) to my PC sound card to have some fun with PSK31 and RTTY.
Has anyone tried wiring a 4pin mic to this radio?
Thanks a bunch
73 VE4BDE
Thanks a bunch
73 VE4BDE
