Hytera MD782i
Uslanru4
Hello dear friend,
How are you doing?
I really hope for your help , a couple of days ago I was given a hytera md782i vhf
Model number: MD782-000G0000-000001-V1-B-A
Unfortunately, I can’t program the frequencies I need,
because I get a “cps Area doesn’t match” error, Please help me solve this problem. This is my first time working with a hytera radio station, thank you very much! good luck with respect !
0xFF1E071F
Check my post here.
You did not mention your radio's area!
If your radio was built for NA you cannot use a SA-compatible CPS, you need NA-compatible CPS
What is your radio's area and what is your CPS version and area!
YL3IM
KO26BX
Making a CPS multi-region
In Windows Explorer, open the CPS installation folder.
Proceed to the config subfolder.
Open tle last archive (either .zip or .7z) inside it.
Open the Model.dat file inside the archive.
Locate the line with [Area] inside the Model.dat file.
Replace the lines below with:
Number=5
Area0=0
Area1=2
Area2=5
Area3=6
Area4=8
Save the Model.dat file into the archive.
Now the CPS should become multi-region. 🙏
Don't worry if the fonts inside the CPS become weird — it's expected and it's considered ok.
Uslanru4
Number=5
Area0=0
Area1=2
Area2=5
Area3=6
Area4=8
Thank you very much You helped me a lot, good luck 73!
Uslanru4
Hello dear colleagues! Unfortunately, I cannot change the channel width from 12.5 to 25 kilohertz, my program does not allow me to do this. Please tell me what changes should I make to the program so that I can make the channel bandwidth 25 kHz? Thank you!hytera-782.jpeghytera-2.jpeg
