HYTERA PD375 FREQUENCY CHANGE
dsankir
Waltham,MA
Hello,
I have EU Hytera PD375 which is 430-480 Mhz.
Any way to change freq. 400-470 Mhz model via sofware?
dazey77
Basically no. there may be physical hardware differences, but even if its sofware, it will be burnt into a chip and not accessible via standard software tools. There is no simple way to do this.
Ebay and buy the one you need!
dsankir
Waltham,MA
There are 2 models in EU market on same hardware.430-480 and 400-470..Thats why i m asking,though can do something.
alcahuete
Southern California
You can expand the frequencies to whatever you want by editing the model.dat file, but the PLL will unlock at less than 10 MHz. If you think you're going to get the radio to work at 400 MHz or close to it, that isn't going to happen. You'll probably be good down to about 422 MHz, if that.
alcahuete
Southern California
My guess is that it would work there, yes. Just research how to edit the model.dat. It's super easy to do. Just change the frequencies for your specific radio in there, rewrite the codeplug to your radio, and you'll be good to go.
dsankir
Waltham,MA
Hi again,
I ve tried today.On CPS,freq. number changed,i ve setting up new frew.on a new channel.On display,it s working but radio does not listening anything.Even its analog or digital mode.
alcahuete
Southern California
Hi again,
Assuming everything was done properly, perhaps that radio just won't open. I don't know. Normally it will say if the PLL is unlocked and you'll get a tone along with it. So I'm not really sure. :( Sorry.
dsankir
Waltham,MA
Thanks for your time and effort...
alcahuete
Southern California
Just read somewhere else, coincidentally, that the newer firmware does not allow this modification. Every radio I have done it on was firmware 7.x. That might be your problem.
