Hytera PDC760 For Amateur Radio Use
JASII
Memory Capacity
I have been giving some thought to a Hytera PDC760 for amatur radio use.
Is anybody here using a Hytera PDC760?
If so, how well does it work?
JASII
Memory Capacity
Can the Hytera PDC760 be programmed from the keypad or is a computer needed?
Pittsboro IN
no front panel programming, pretty odd for this high end radio.
The CPS is different from all the others, much more graphic.
I've been trying to update the firmware but get an error, I might be missing a plug in which is something unique to the PDC760.
JASII
Memory Capacity
I bought a used PDC760.
I want to use the built-in DMR hotspot feature.
I assume I need the programming cable and software even to do that, right?
JASII
Memory Capacity
I have been charging my PDC760, but the battery never gets to 100%. Do I just need a new battery or should I try something else?
Pittsboro IN
The battery should have a serial # similar to or same as the radio. First 2 digits are the year, that should give you an idea of how old the battery is. I don't think there is a way to see how many charges the battery has had. My radio is from 2018 and has had very few cycles so it gets 100%.
JASII
Memory Capacity
I am looking for the programming cable PC93 and software for the Hytera PDC760.
Does anybody here have it or can you recommend a good place to get it?
