Hytera PNC380
Forts
Ontario, Canada
I picked up one of these radios and was able to get it configured with Zello and it's working great. However every time I power it up it repeatedly tries to login to the Halo app which gets annoying because it boots you out of other menus. Has anyone had success disabling or removing the app over ADB? I might give it a try but I'm curious if their might be unknown side effects of removing the app. It seems to settle down after a few minutes when it realizes it can't login, so it's not a huge issue... But still has me wondering.
Thanks!
Forts
Ontario, Canada
For anyone that might find this in the future, this seems to have done the trick...
adb shell pm disable-user --user 0 com.hytalkpro.ocean
70cutlass442
Thanks!
I am looking at these for myself and a customer to interface to a LMR system. Could you explain a bit more on how to remove/disable the Halo APP?
Have you tried the emergency button and does it work on Zello?
Forts
Ontario, Canada
I use mine only for receiving. I've not made any attempt at mapping the PTT button to Zello, and I really don't see how you would send an emergency over Zello.
Disabling the Halo app is done thru ADB (Android debug bridge) which is a command line interface that allows you much more access to the operating system.
70cutlass442
got it. Zello emergency button steers the radio to a designated radio channel and maps the location to the other recipients. I am using the free enterprise version for first responders and there appears to be additional settings for the emergency button in the enterprise version.
