As mentioned your firmware and CPS versions are fine. It could possibly be that it doesn't show as enabled under Feature Control but I've had radios in the past that were like that and had no issues (since the feature was added for free in the firmware). Definitely try the simplest setup first. Use a conventional simplex channel, KID=1 and a key of 1111111111 (or similar..just something dead simple). What I like to do is program 2 channels for testing, one in the clear (so I can confirm all other settings are good) then one with encryption enabled.
Sir.
I have reprogrammed the CPS and now works good in direct mode.
It is true that in basic encryption receive ARC4 good. (Direct mode).
However, now my problem is that receiving in the Hytera, from a Motorola radio through repeater, the call is mute. I can see the called ID and TG. However no sound. If I use a anytone878 to receive no problem.
No RAS on the repeater.
I can’t see on the Hytera CPS any option to select direct or repeater mode. So in the screen I see RM (So it is repeater mode).
My doubt if I need to put a configuration in the Hytera to work better with a Motorola.
Dmr trunking is not active. So I think that I don’t need that (Only for TIII, no?).
![IMG_5203.jpeg IMG_5203.jpeg](http://forums.radioreference.com/data/attachments/152/152785-c3b99aee7fcd6c90452969f47bba5650.jpg)
