SDS100/SDS200: I accidently installed the TxWarn system
texaztea
Henderson, Texas
I accidently installed the TxWarn system on my new SDS200. I also put a very few local police depts. as well. I'm a newbie. Whenever I turn the scanner on, all it wants to do is scan TxWarn's many cities in Texas. This is all I get. Can I go into the SD card and delete TxWarn, and start over? Thanks.
Whiskey3JMC
Lemme show ya sumthin
Simulcastylvania, TE
Welcome to the RR forums. First and foremost turn off full database scanning if you enabled it (entering a zip code for instance turns it on)
  • Full Database: Off
Then use Sentinel to program a favorites list containing only what you want to hear. Note that Sentinel will append every site, department & channel (or talkgroup) in a particular system so you'll need to go into the favorites list editor and remove what you don't want. Proscan allows for greater favorites list selectivity (check boxes pertaining only to the items you want to add to a FL) which is one of the many reasons I prefer it for building FLs over Sentinel. You get a 30 day free trial then $50.00 gets you two activations and periodic updates. A Radioreference premium subscription is a prerequisite to use RR's web import service for the best FL creation experience
drdispatch
If 1000 hertz, think what 1 gig must feel like
Fightin' River, Michigan
If you're using Sentinel, don't append the whole system; just append the departments or talkgroups that you want. It will still append all the sites, but all you have to do is delete all but the ones most likely to carry the traffic you want to hear. It also will depend on if you are using the scanner stationary or mobile.
hiegtx
Mentor
Dallas, TX
Sent you a Favorites list, in an *.hpe file, in a "conversation"/ Look at the small envelope in the upper right corner of the page, next to your member name, to access the file.
