i cant get the audio from my scanner it only gets my micphone from my laptop can anyone help me
mkhakanson
i cant get the audio from my scanner it only gets my micphone from my laptop can anyone help me and my radio is baofeng UV5R
1808208
Hawaii
Go into the control panel. Under sounds, under recording devices, disable internal mic. Set other input as default. There might be more than one listed, find the one that is tied to the scanner.
gmclam
Fair Oaks, CA
Right click on the speaker icon. Open volume control. Select Options -> Properties. Click the Recoding option (Playback is typically selected). Click OK. That should bring up your Recording Mixer. You'll not only want to select the desired recording source, but also set the level.
