I hate the Btech UV Pro !
Threeolives
Illinois
Cant get it programmed to work with my TYT uv380s, Cant get any help from Btech ! cant get the .csv file converted to work with btech. Cant load with anything other than a cell phone. My code plug was originally from a Motorola, i have it so i can load a TYT in 30 seconds. I have RX groups, scan lists, digital contacts nothing loads on the pro except the channel list.
Threeolives
Illinois
This dosnt sound right, i dont know of a programming cable.
You can program the TYT MD-UV380 to communicate with a BTECH UV-PRO, but it requires using software and a programming cable to ensure all settings are identical
. For cross-brand communication to work, both radios must be programmed to the exact same settings for frequency, mode, and digital or analog privacy codes.
Coffeemug
Warminster BUCKS Co. PA
I don't mean to show disrespect to those who regret purchasing the BTECH UV-PRO, but I like mine. I mean yes, there are some things that I'm not too happy with, but overall, it's a decent radio. Easy to program via Bluetooth app on android or I Phone Operating System. Even using HT Commander Program is simple to use. I just wish that BTECH used a larger capacity battery, because the radio really such up a lot power when used. I sure hope BTECH produce a UV-PRO plus that would have DMR / IDAS/NXDN as well as analogue, because giving more choices and the ability to program on the fly is what amateur radio operators look for.
KD8DVR
Columbus, Ohio
That won't happen. Anytone is coming out with an Analog/DMR/NXDN radio soon; but that's probably as close as you'll get.
Coffeemug
I know that BTECH probably won't have a line of radios that be compatible for DMR and NXDN, at least not anytime soon. However, I wouldn't necessarily say that BTECH won't produce such radios. If they did, between the tariffs and the mods themselves, that will drive the overall cost the radio up. Especially, with a radio that will operate all three modes. Nope, I would hold out a little while. I mean ICOM and KENWOOD are both excellent manufacturers, but their way over price, especially used
