i hear lots tlak on 123.45
SkiBob
Out Yonder, GA
It's one of the air to air frequencies. Yes, you will hear commercial pilots use it as well. I would suggest adding all of the air to air freq into your scanner.
122.75 (fixed wing)
123.025 (helicopters)
123.400, 123.425, 123.450, 123.475, 122.9, 122.85 and 122.775
KB7MIB
Peoria, AZ.
Officially, it's a flight test frequency, and is only supposed to be used for that.
Unofficially, and against regulations, it's used for air-to-air chit chat.
John
Peoria, AZ
kcoleman
Tallassee, AL
I hear it used frequently in my area too. Like others have said, it's an unofficial air/air frequency.
Keith
ind224
Indianapolis
123.45 had been unofficial air to air for decades in the US.
I found this document but am having a hard time trying to confirm if this is an actual change "order" or just a filing / request to do so.
If this is the actual order and a tap on the heart while saying "Make it so Number One" happened, this was back in 2008. Notice the link in the addy says "order" implying it is a done deal.
http://www.faa.gov/documentLibrary/media/Order/6050.32B Chg 1.pdf
I love listening to 123.450 and start the recorder because you never know what direction the conversation may take.
majoco
Stirrer
New Zealand
Worldwide - even on long overwater routes, you'll find one radio in the cockpit on 123.45. Often a conversation will last a while with aircraft going the same direction, or just a quick "I see you!" as they pass in opposite directions. The reply is "I see you too!". Aircrew always have lots to talk about, a few conversations start off with "Is old fred bloggs still working for you...."
autovon
Ø
123.45 (in addition to 121.5) is supposed to be monitored while oceanic.
kc2kth
Toms River NJ
check the wiki.
it's there.
Do you have a link? I'm not sure where to look in the Wiki pages - don't see anything air specific there. I'd like to get something better put together for air monitoring than a simple range search or a full db - zip code search on my 436. I'm too far to hear much ground or tower, but I can hear traffic in the DC, NY and Boston zones.
falcon21
WI
I've used 123.45 to test a new transceiver setup. I haven't noticed much chatter on it near me but I don't monitor it as I'm usually tuned to the airport I'm flying out of.
