I seem to be missing something.
daveo89
Rochester NY
I'm using the RTL-SDR with the SDR Sharp program. I have installed the plugin for the Frequency Manager + Scanner. It seemed to be loaded properly but on the FM-Scan window. The lower portion of the control panel is missing. Could some one please point me in the right direction to fix this? Thanks.
32dave
Oxford County, Ontario Canada
Try getting rid of source and radio really don't need them up and take fm suite and join it to that side if that is what you mean
dave3825
Suffolk County NY
OP showing a floating window where as yours is docked.
@daveo89 does that do the same when docked and not floating?
dave3825
Suffolk County NY
What is your screen resolution set to? Wonder if the programs maybe scales it down or something.
daveo89
Rochester NY
It's set at 1600x900. But I saw something on another thread about it and tried a few other settings with no change. I am running the current version of SDR sharp, v1921, and I wonder if an earlier version would suit the plugin better. I'm going to look them up and try that. Thanks for the info.
daveo89
Rochester NY
After much reading on this site and playing around with many versions of SDR#, I settled on getting the scanner to work properly with all the buttons. It goes like this: SRD# v1921, dotnet 8. The scanner version is v2.4.4.0. This is on a "Windows 11 machine with a RTL-SDR dongle. It was quite a journey but most of all, I learned a lot. Thanks to all for their help.
