I wrote a program called scanner screen for uniden scanners I would like to add whistler scanners
Vonskie
Allen, TX
This may be a stupid comment and completely worthless, but the GRE-based scanned don’t connect directly via serial to a computer, you have to use an adapter that plugs into your USB port, then into the PC/IF lack on the scanner with electronics in-between.
Could this be what’s causing your program to not connect?
Once the usb cable is connected it should show up as a com port in device manager
Its a virtual thing
Ubbe
Stockholm, Sweden
Von, I get "no response recieved" as well with the test program.
I see that you use CreateCommand(#39'V'#39, #0); when there should be no #39 characters added.
/Ubbe
Timeout occurred while receiving response
Failed to send command for model number
Failed to send command for channel info
Vonskie
Allen, TX
I fixed the time out problem
Now its just capturing the correct data for the scanner and dividing it up
Ubbe
Stockholm, Sweden
If I change the SerialPort.RecvString to SerialPort.RecvPacket it responds with error: OK.
So it needs to handle the response as a data packet.
If I comment out a lot of lines it responds with the model in the error response.
/Ubbe
Thank you for all your hard work on this, I'm sure with the help and suggestions by @Ubbe and @KevinC it will soon work. I'm not a programmer so I can only test it after it is done
Ubbe
Stockholm, Sweden
I commented out a little more about checksum calculations and error reports and then if I send model request 3 or 4 times it somehow clears the serial buffer, it receive garbage characters, and the text box then shows the model on each request, and also the channel info works and seems to be correct at every value. But there's come characters it doesn't like to receive, perhaps the STX ETX or the ones that echoes back from the command.
/Ubbe
/Ubbe
This sounds similar to what I see in the Whistler Control Demo software as well.
Vonskie
Allen, TX
So is it n81 or n80 as uniden is n80 and I think whistler should be n81
That parity stop bits and etc
Perhaps the garbage characters are caused by that #3 and #2 are normal
Ubbe
Stockholm, Sweden
It could have something to do with 8n0 versus 8n1 but it seems to respond as it should using ScannerScreen's 8n0 and what I could see with the test program, after editing it, all the TG and ID for a trunked system show up in their correct places in the result box.
/Ubbe
