Are these RJ12 or RJ 25? (not the RJ45 Mic jacks)
RJ12 and RJ25
Both are almost the same and the only difference is the wire type used:
RJ12 is used with solid wire.
RJ25 for use with stranded wire.
See the LocoNet article for more information on the RJ connector series.
The RJ12/RJ25 are used to make a throttle network cable. The difference is in the wire type used:
Using the incorrect type for the wire being crimped onto will result in problems later. The "stabs" on each pin are designed for a specific wire type.
- RJ12 is used with solid wire
- RJ25 for use with stranded wire
No it won't. Most 4 or 6 conductor phone cables along with pretty much all Cat5/6 cables are made using solid wire conductors and they sure aren't stiff.A control cable made from solid wire would make for a very stiff cable. It would be like using household Romex for a control cable.
