Icom: IC-9700 microphone
jazzboypro
Laval
Hello all,
Just wandering if any IC-9700 owners have changed the stock microphone and if so what are you using.
73
Sylvain
Hit_Factor
Saint Joseph, MI
I move this between my IC-9700 and IC-7300 has needed. Operated with a foot switch.
Reason for changing mic? simply for the convenience of a foot pedal and a boom, handsfree operation.
prcguy
With a little internal EQ and compression, the stock hand mic will sound better than any other radio with an expensive mic. Otherwise the Icom SM-30 is a reasonably priced plug and play desk mic that sounds a little better than stock.
Hello all,
73
Sylvain
jwt873
Woodlands, Manitoba
I haven't replaced the stock hand mic yet. I'm actually quite pleased with it.
I have a Heil Pro Set headset with the HC5 mic element. It works great with my IC-7600 in combination with a foot switch. But for some reason I can't get enough drive out of it for the IC-9700. Will be following this thread...
WB9YBM
that reminds me of an item Heathkit used to sell, called a "microlizer" (microphone equalizer)...
prcguy
The 9700 is very similar to the 7300 and 7610 for mic gain and EQ settings. I use a Heil PR-781 and EV RE-27 on my 7610 and that requires 100% mic gain and some higher than usual compression settings, but it sounds fantastic. Have you tried 100% mic gain and other settings yet? My 7610 settings are mic gain 100%, compression wide, level 8, TX EQ bass -3, treble +5. These settings sound very smooth but punchy on big dynamic mics and the HC5 would probably benefit from a little more bass and less treble.
jazzboypro
Laval
I'm looking into this microphone, with the foot switch, the boom and and shock mount. By looking at the FS-3 footswitch it is my understanding that i also need to but the CC-1 and AD-1 cable systems to make it all work ?
Hit_Factor
Saint Joseph, MI
This is what I bought from DX Engineering
Items Shipped:
Item
Qty.
Track: Box*
Carrier
Est. Arrival
HLS-ICM-BG
Microphone, iCM, Standard Type, Black Body, Gold Screen, Single Element, Electret, w/ cable and 8-pin Round for ICOM Xcvr Only, Each
(Mfr. #: ICM-BG)
1​
UPS​
2-4 bus. days
DXE-FS-003
Foot Switch, Extra Wide, Super-Duty Cast Metal Pedal, Single-Pole, 8 ft. Cable, Mono Phone Plug, Each
(Mfr. #: DXE-FS-003)
1​
UPS​
2-4 bus. days
prcguy
If your going to spend that much just get an SM-30. There is nothing special about the Heil mic, its just a 99 cent pencil eraser sized electret condenser capsule like you would find in a cordless phone. The SM-30 is plug and play with a manual gain control that will get a little louder than the stock hand mic and it will sound a little fuller and better.
