Ic-F30GS scan help
Baker845
Oregon
Does any one know setting i need to scan one bank at time? The radio scan bank 1 good, But when i go Bank 2 and scan the radio still scans bank 1. there setting i not doing?
thanks
Baker845
Oregon
I see how the set group, but it doesn't stop on the channel that talking?
stmills
Twin Cites Area MN
I am guessing you have the programing software and are not just trying to do this from the radio alone.
You can have up to 10 scan lists.
Each channel can be in any scan list- in the software you select the lists 0-9 by checking the boxes on the channel edit screen.
To switch scan lists- hold the Scan start stop button for about 1 second, the uses the up or down channel buttons to advance through the scan lists you want to use.
Baker845
Oregon
Ok, i got it. I missed that step holding bottom.Im using software. If i use more then 10 banks will i be able to scan them.
thank you
stmills
Twin Cites Area MN
Wirelessly posted (Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 8.12; MSIEMobile 6.0) Sprint S511)
I am had the exact problem trying to move between scan lists when I first got the radio. If you keep the scan list pure to 1 bank only then you can not scan all banks. I have some scan lists that cover more than 1 bank and some banks that do not have any channels assigned to scan lists.
