This is a known problem with the IC-7100.
The control head gets its power over the extension cable with the shielded RJ45 connectors. That includes power for the audio amp in the control head. If you have the radio configured to use the speaker in the control head, loud sounds will cause the audio amp to draw more current than the soda straw, aka control cable, can pass.
About the only solution is to turn down the volume or connect an external speaker to the RF deck.
