It's actually helpful when using a trunked system or simplex over a longer distance from other units, Essentially the difference between wearing radio on your hip level vs holding in your hand almost two feet higher. We use them for task force etc. Actually work well for the purpose.
The M.A.S.T. allows tactical operators to relocate their radio antennas to improve line of sight communications, reduce the potential for interference caused by certain types of radio antennas, and decrease the visual obstructions caused by standard antenna configurations Please note, MAST Kits...
safariland.com
Around 15yrs ago when I got my first Thales PRC-6809 MBITR I experimented with VHF lo band and dangling pig tail counterpoise wires then remote antenna mounts on a backpack for the factory short and 1m long blade antenna. I had a bunch of field strength measurements that proved the pig tail counterpoise increased performance and also raising the antenna up high on a pack vs on the radio at belt level. My final testing was a remote antenna mount up high with 5ft long pig tail and while I don't have the data handy it was quite an improvement over the antenna mounted to radio and lower on the body.
I was a member of some military chat groups with radio guys and was telling some of them about my testing and one guy who claimed to be a medic asked if I could send him a version of what I was testing and I did, sent it to his military APO address which eventually got to him in Afghanistan. The setup was a double female TNC adapter attached to a MOLLE clip with removable 5ft pigtail ground and two different TNC to TNC coax assemblies, one made from a good quality US made RG-58 and another made of miniature Teflon RG-316 coax. Both had a a few wraps of the coax through a 61 mix ferrite bead near the antenna end as an RF choke. All metal connectors were painted flat black and I used thick hot glue heatshrink for strain reliefs on the coax.
The user reported back only once that it worked very noticeably better than their typical radio on chest with antenna attached to radio setup and also much better than some goofy long shorted RG-58 antenna thing that weaved up and down through loops on a pack that was all the talk with mil radio people at the time. I tried contacting the recipient of my stuff several times after that with no reply and I never knew what happened to him.
About 6mo later the TCI MAST antenna relocation kit shown above hit the market. WTF??? That was my idea but they left out the RF choke and pig tail counterpoise. And they charged a lot of $$. Oh well, not the first time I've been ripped off and probably won't be the last.
