Ed403
I am a newbie here to the programming of this 208H radio. I have the software and the cable to program it with. I got that much down. HAHAH..
The questions I have is this. There are 3 columns for "tones". 1 states "tone", 1 states "tone squelch" and the other states "DCTS". I know what the DCTS is and how that is worked. The problem I face is with column I would use for "tone" or "tone squelch". it appears that both columns pull down menu's using the CS-208 software have the same grids with the exact same numbers.
Here is an example of what I am looking at: Let's say I am using the frequency of 460.3000 with a tone of 123.3. If I look at "tone" column, I have that 123.3 in the pull down grid. If I look at "tone squelch" I also have 123.3 in that pull down menu as well. So which one would I use, or does it matter??
Second question. When programming VHF High frequencies, most of them are aren't the common DUP 5.0+ or - off for repeter operation. Let's say I want to program 155.745 with an input offset frequency of 153.7400. Would I put in 2.005 DUP- in the offset column or use the common 5.00 offset in the DUP -??
These 2 questions my have been answered somewhere on here, but I have not been able to find them. I an not a ham operator, just a newbiee on programming this radio for a friend of mine. Thanks in advance for any and all advice and you may email me direct at khp403@sbcglobal.net if anybody would prefer.
Mike
Mike
