Icom: Icom 7300 Questions
AB4BF
EM93cs
On my 7300, when the frequency is touched on the touch screen, the operating band pop-up appears. All the US bands appear as frequencies. At the bottom of the pop-up, a push button labeled "GENE" is there. Who or what is "GENE"? Is it maybe short for "Generate"? Is it programmable? The only mention that I can find is in the programming section on page 19-10 and it is listed as "other than above".
Also, in the index, a listing for "OVF" is there and listed on page 3-10. I can't find it on the page. I'm probably looking over it, but I haven't found OVF yet. What is OVF?
N1FKO
Gene is short for General Coverage, frequencies outside of the ham bands (read up on band stacking registers).
OVF is short for Overflow, indicating a too-strong signal.
RMason
Colorado / Mississippi
From Page 3-10:
RF Gain:
If strong signal is received and "OVF" (Overflow) appears, reduce the RF gain until "OVF" disappears.
If you don't have the (searchable) pdf user guide, you can download it from:
AB4BF
EM93cs
Thank You Both, Gentlemen, I really appreciate the information. General Coverage and Overflow. I'll write that in the notes section so I won't forget it!
AB4BF
K6GBW
Montebello, CA
What version firmware are you running? The OVF issue was fixed in the last couple of firmware releases. Even if you are getting an OVF indication you can simple dial down the RF Gain a bit.
AB4BF
EM93cs
Sorry for the late answer, Dr.'s appt. all morning...
I just recently updated the firmware to 1.42. Icom makes it the easiest firmware to update on the 7300! The OVF was listed in the "big" manual with color, but I just didn't see it, RMason showed me where it is (Thanks, Again!). The other is still kind of a mystery. GENE is General Coverage and the button is programmable to input 3 frequencies, but I haven't found how to input those 3 frequencies, yet. I would think its the same way all the other buttons are programmed, I just gotta find it in the manual. I'll figure it out eventually...
Funny, the OVF was explained in a video I watched last night, still looking for a video for GENE!
AK9R
Staff member
Super Moderator
Central Indiana
The "GENE" button on Icom HF radios is there so you can easily access frequencies anywhere within the radio's range of reception rather than the preset band buttons that take you directly to frequencies in the labeled band. Keep in mind that you can still spin the VFO knob to access other frequencies even if you've tapped the "7" or "14" buttons. Same with the "GENE" button.
As for the band stacking registers, the 3 frequencies you refer to, it works the same on the "GENE" button as it does the band buttons. Tap "7" and tune to a frequency. Tap "7" again and tune to a different frequency. Tap "7" again and tune to a different frequency. Tap "7" again and you'll be back at the first frequency. The "GENE" button does the same thing.
The band stacking registers are not memories where you might save a frequency. They are a 3-frequency rotating ad-hoc scratchpad.
W7ITC
Cheyenne, Wyoming
ICOM Firmware V. 1.42 (May.16.2024) only addresses the IC-7300's operation with the ICOM IC-PW2 HF power amp, and add's a manual reset with the factory power supply that is not available in the states. I don't run a "Penny Whistle" so there is no reason for me to update.
AK9R
Staff member
Super Moderator
Central Indiana
Your choice, but there may have been fixes "under the hood" that weren't documented in the publicly-available release notes. In my experience, Icom is pretty careful about firmware updates. Rarely does an Icom firmware update "break" something...unlike other radio manufacturers.
VK5AC
Adelaide, South Australia
After 20+ years servicing and repairing and updating broadcast transmitters to 20KW, associated signal source and processing equipment there is always a good idea to update firmware to the latest (unless there are reports of catastrophes!). So often there is no recognised or achknowledged issue and yet it is in the supplier/manufacturers interest to fix (what they admit to) and (what they don't admit too)
Point in place. My s/h 35000 hours 2000 -1005 HP Agilent 3GHz signal generator had 3.50 software and worked fine. Then after a few months started having some sort of communication between boards problem. Mainly reference module. Ok bite the bullet, updated the firmware 3.86 last produced (nothing related to this problem was acknowledged or reported) and viola, no more problems, all functions now work smoothly. It just does its thing. Seems there were many changes (not admitted to) that had occurred under the hood. Note: this was 19200 baud serial taking over 1hr!
TNO Trust noone security thinking. They are lying sods not telling the truth. However they have a vested interest to solve as much as possible as their reputation and long term viability rides on how good their product is.
Any FW update once installed by a few with no reports of disaster, I then do. Of course taking ALL care and precautions, reading all information, using only the correct files after full research. So far these updates personally and commercially have all been worthwhile.
Also apart from above. Support requests to major manufacturers results in the FIRST question, "what level of firmware are you?" Not the latest, we have available then just go away and dont come back, until the latest is installed and they know that a firmware + factory reset will resolve many problems so they dont have to deal with them.
FW updates, I do the lot.
