Icom CS-f50v program issue
Whfd2125
Nashville, TN
im having trouble programming the icom ic-f50v . i can read but cant write. i saw on previous forums here that use the newest revision software i currently have 3.1 and after following instructions about finding the version on the radio it say 3.6 is this why i cant write ? if so where can i find the newest revision or is there something else i can do
tecker
Deshler, NE
Do you have version "3.1" or "3.1 MM"? That "MM" might be the issue if you do not have it. Many of the new Icom F50v transceivers have the MM firmware (which I think includes 3.6) which requires the "3.1 MM" software to program. Check with your dealer to see if you can get a newer version of the software from them.
Also take a look at this thread. Sound about exactly what you are dealing with: http://forums.radioreference.com/icom-land-mobile-radio/314371-ic-f50v-programming-issue.html
jeatock
090-45-50 W, 39-43-22 N
It's an Icom thing...
The 'Home Company' has two versions of F50V software. Both will read any radio.
BUT TO WRITE you need the software version with the same number of digits as the radio firmware.
CS-F V3.x.x will read but not write radios with FW ver v3.x
CS-F v3.x will read but not write radios with FW ver 3.x.x
Hope this helps. KB-D34C586555 is marked dealer access only as it includes dealer access to the software downloads on icom's B2B site. The following is from the .pdf file stating which version of CS-F to use. The .pdf may not be available on the public KB at icomamerica.com.
Knowledge Base Article D34C586555
F50V Software and Firmware Compatibility.pdf
There is new software for the F50V series radios. The firmware in the radio determines which software is compatible with the radio.The versions for the new software and firmware are designated with three digits, not two as in older versions e.g. v3.1.1, not v3.1.
Important: Software that has a three digit version is not compatible with firmware with a two digit version; Software with a two digit version is not compatible with firmware with a three digit version.
What Software and Firmware to Use
Current radio software and firmware:
Software CS‐F50V MM v3.1.1 or greater uses firmware FL3060A v3.6.2 or greater.
Older radio software and firmware:
Software CS‐F50V v3.1 or less uses firmware FX3060B v3.6 or less.
Check Your Firmware
To determine which software your radio is capable of using, check the firmware.
1. Press and hold the Up Arrow and P3.
2. Switch the power on.
The display will show the firmware version.
You can also check the radio firmware version from the cloning software at the Clone ‐> Information window.
