ICOM F5061D programming error
eduandup
Hi everyone,
I recently purchased an ICOM IC-F5061D and have been trying to program it using the CS-F3161_CS-F5060 software. I'm able to successfully read the data from the radio and view the current configuration. However, when I try to write to the radio, the process begins but fails partway through (sometimes a quarter of the way, other times halfway), and I get the error:
“No answer from Transceiver.”
After this, the radio displays “CLONE NG” on the screen.
Now, every time I try to write to the radio, it still fails and gives the same error message. I’ve checked the Clone Information, and the radio shows it is Revision 2.8.
So far, I’ve tried the following versions of the programming software:
  • v5.0
  • v5.2
  • v2.2
All versions give the same error.
Has anyone run into this issue or have suggestions for a solution? Any help would be appreciated.
Thanks in advance!
Radio99
NW Chicago Suburbs
Latest version of the software is 5.3
It isn’t a railroad version, is it? That takes special railroad software.
eduandup
I do not think it is a railroad version. I have also tried the railroad software version V4 Revision 4.6.3 but that did not work either.
jeepsandradios
East of the Mississippi
Did you try a read then direct ot a write without changing anything ? Ive only had that happen with a USB cable. Mine are all serial for the mobiles to eliminate that issue.
eduandup
I used a USB cable that has a CP210x USB to UART chip. I think my cable may be the problem, as today I went to one of my local radio dealers and they had success programming my radio using the same version of the software, just a different cable.
V6PBE
POHNPEI, MICRONESIA
The problem most likely a hardware mismatch (programming cable). I hope the problem is corrected in order to program anytime you wish to.
westcoaster
I had a similar issue with some IC-F5061 radios I had purchased used as well.
Thread here: Read but not write to Icom IC F5061
Ultimately, the solution for me was to upgrade the firmware on all the radios to firmware version 5.4. (as indicated by holding the P0 and P3 buttons while powering on the radio)
Edit: the firmware upgrade was pretty easy....
I did lose the EMDC function, but that wasn't something I was using anyway....
V6PBE
POHNPEI, MICRONESIA
Hi, did you try to write your information in the ZONE 1 under the Memory Channel without having to READ first? Sometimes, you just need to fill out the ZONE 1 and write to the radio. Then you can read the radio afterward. Hope this helps. Thank you
Bert
VK2TPD
NSW Australia
From memory version 2.8 will need to use CPS 2.8 or earlier or update the Firmware to revision 3.00 before you can upgrade to a newer version. Icom changed something in the CPS, so REV puts the update in.
Pete
