Icom IC-F4TR programming
spsison
HENDERSON, NV
Hello All! I have the software and programming cable, but the read radio does not read anything. Does anyone remember if I need to press any buttons when I turn on the radio to enable programming? Thanks
I never had to on my F4 (non-TR's). Just plug in, turn on the radio and read is all I remember. I was using the Icom OEM programming cable that was serial/DB-9.
Make sure the plug on the side is seated all the way. That was a common issue back in the day. I recall having to push harder than seemed logical to get it to seat all the way and connect.
spsison
HENDERSON, NV
If there are no buttons to press when turning on the radio, this could be a software and/or cable issue. I bought the cable (USB) on eBay.
Make sure it is the correct software. The standard F-3/F-4 software will not work on a "TR" model radio.
These radios are older than dirt, and it could be an issue with the radio. Make sure the jacks are clean and not full of dust/lint,boogers, etc.
Never tried a USB cable, I used the straight RS232 serial cable. I can't recall if I ever tried it with a USB to serial adapter.
Make sure you have selected the correct comm port in the software. Use your device manager to confirm what comm port the USB cable is using.
12dbsinad
Also the 1/8th jack very prone to go bad on those old rigs. Put a little side torque on the cable while trying to read. Of course, that'll only work if the radio likes everything else like your USB cable/drivers, correct software, etc
spsison
HENDERSON, NV
Nothing worked yet. The USB cable claimed it will work on the F4TR and other Icom radios. I tried the cable on a IC-T7H and it worked. I tried using windows xp, 7 and above, but it didn't work on the F4TR. The schematic for the DB9 cable is all over the web, I'll build one and will boot in DOS.
spsison
HENDERSON, NV
Db-9 cable worked now. Thanks to all your inputs. Another question, do you know the default dealer or tech password?
