(Sanner Radio layman here….)
My old ICOM IC R2 appears to have lost a lot of its ability to receive frequencies that it could easily pick up in the past.
Perhaps something has malfunctioned within the radio that is not fixable.
I am, however, hoping the issue has been caused by a setting that I enabled accidentally or an antenna issue.
I can Scan a few known frequencies and sometimes they come in, so the radio is functional to an extent. But most of the time I cannot get frequencies to come in.
Just before this issue, I purchased a Diamond SRH77CA Antenna to see if I could pick up more frequencies. Perhaps that antenna overpowered a circuit within the radio and caused the problem ( is this even possible ?). If so, there is nothing that can be easily fixed or adjusted.
I performed CPU Rest (Hold [FUNC] & [BAND] & [V/M] buttons and turn the radio on). This reset has not provided any improvement.
Does anyone know how I can test the radio to pinpoint where to look for a solution?
For example, if set up and connected the radio’s SMA connecter to a Random Wire antenna, would that give any insight into what is happening?
If this issue can be rectified by antenna modification that would be great.
