ICOM ICM330GE programming
TR16GSY
Hi All,
I'm really struggling to find out how to connect the OPC-478UC cable to my VHF.
I'm understand that that is all I should need for programming the radio. I see that the orange and grey wires on the back of the VHF are the data lines but how do I connect them all together.
I have the correct software and have programmed handhelds before but I can't find any further info to help.
Thanks in advance
ojfd
I've programmed some of my Icom marine radios, so maybe I'll be able to help.
Does it have 4 pin connector consisting of
black
blue
grey
orange
wires in that order?
ojfd
Sounds good. You have to cobble together some sort of adapter that connects OPC-478UC and that 4 pin connector on the back of IC-M330G this way.
(I hope you know that there are two versions of original Icom OPC-478UC cables. Older ones only work up to Win 7. With clones it is a bit of hit and miss)
I use this type of adapter when I need to connect to Icoms that have odd connectors (like IC-M422 etc.).
