ICOM PCR Web Controlled Receiver
KC1UA
Scan New England Janitor/Maintenance
Marstons Mills, Cape Cod, Massachusetts
Unfortunately I'm getting what appears to me to be the exact same behavior. To confirm:
DEFAULTBAUDRATE=9600
The only "difference" I'm hearing is a "pop" in my speakers when I click the power button during the first connection. There is white noise coming from the speakers as there was in the last version. It does not change when I change modes or bandwidths so I don't believe I have any control over the radio yet. Interestingly, the AF Gain control needs to be adjusted to 12 o'clock before I hear any noise from the speakers, and as soon as I reduce it to about 11 o'clock the noise disappears. This however was the case with the version prior to this one as well.
After powering it down and then trying to reconnect it behaves as before, power does not come on. I wonder if the COM port is getting hung after the first connection given the OpenPort error.
Again, first.txt and second.txt are attached with debug info.
Thanks for continuing to try.
  • first.txt
  • second.txt
KC1UA
Stranger and stranger...
I shut down the browser, restarted it and tried connecting again. It connected and I heard our local NOAA Weather Broadcast station on 162.550. It started in USB mode and I was able to change it to FM with a 15 KHz bandwidth. However, after about 20 seconds it failed and returned to the above behavior.
I managed to get it to do this again, attached is the debug file for it.
Edit: I should note that for the debug file it started in FM with 15 KHz bandwidth.
  • fail after 20 seconds.txt
jcarlos
Not at all. I am waiting for a friend who will provide me with a PCR1000. I will be able to work remotely with it and I hope I will got it.
..JC
