Icom R5- Best Software
Favorite Icom R5 Software
  • IC-R5 ([url]www.ic-r5.com[/url])
    Votes: 0 0.0%
  • tk5 ([url]http://parnass.com/tk5/[/url]
    Votes: 0 0.0%
  • CS-R5 Cloning Software (Icom OEM Software)
    Votes: 1 50.0%
  • The old fashioned way, dials & buttons & knobs & such
    Votes: 1 50.0%
  • Total voters
    2
  • Poll closed .
2ManyToys
Mt. Vernon, Iowa
OK, receiving a used Icom R5 from FedEx today. With it came the programming cable but no software. I'm wondering which software to use, so time for a poll of the experts...
Please vote & comment on your favorite R5 programming software.
So far I'm leaning towards IC-R5 as it seems less clunky then the Icom OEM software but still will import from the Percon/Icom America database.
burner781
Flatwoods , Kentucky
I use the OEM software and it works well for me. I use it mostly for MILAIR and I only put in a couple freq's at a time. If you want to import OEM is not the way to go. But if you want to make small changes now and then it's not bad.
2ManyToys
Mt. Vernon, Iowa
LONG reply...
I bought & have tried to use IC-R5 w/o any luck. Also tried the tk5 but couldn't get it to run w/o crashing (on two different PC's).
This little bugger is kicking my a**. I've spent a number of hours trying to load frequencies & other then the default config. provided with the IC-R5 software I can't. I hate to surrender but the R5 may have to go on the block. 1st electronic gadget that has ever beat me. :mad:
Here's the main issue. I can load a single .icf file, either the default freqs. or a .icf file downloaded from the Percon site. But I'm not smart enough to ADD/COMBINE frequencies to an existing file.
What I want to accomplish is to load the default config. & then add additional groups of frequencies from the Percon database. But I'm unable to ADD from the database. When I import the files they just overwrite the current frequencies. Plus AFAICT there isn't a way in IC-R5 to select more then one line/frequency at a time. Rather then select a bunch of frequencies to move them to other channels/banks, it must be done one-by-one.
I'm not willing to blow more $$$'s for the OEM software if I'll have the same issues/restrictions.
Grrrrrrrrrrr Anyone want to buy a Icom R-5?
