R8600 Icom R8500 vs R8600
prcguy
Above 30 MHz, only my discone is selectable. below 30 MHz, only the wire is selectable.
Below 30MHz I can select one of three antenna inputs, above 30MHz it defaults to antenna 1. You can select different inputs via the FUNCTION button or when below 30Mhz under the mode icon it will show what antenna is selected and you can use the touch screen to change it.
kruser
Well Known Member
W St Louis Cnty, MO
Is your R8600 the US version receiver? Running the latest 1.35 firmware version?
All 3 antenna inputs become a user selectable option on all freqs below 30 MHz. At least both my 8600's allow me to choose any of the 3 Ant inputs when tuning below 30 MHz.
This is inline with what others have posted including the fact that when tuning 30 MHz and higher, only Ant 1 is used and cannot be changed.
I've never seen an 8600 that didn't allow the user to select any of the 3 antenna inputs when tuned below 30 MHz which is why I asked the question if yours is the US version or one of the other regions that may have the old analog AMPS cell band unblocked. I have no idea if the other regions models may limit which antenna input you can select below 30 MHz and I see no reason why they would have such a limitation really.
N9JIG
Sheriff
Moderator
Far NW Valley
@bearcatrp: When tuned to a freq below 30 MHz. you should see the "ANT1" indicator to the left of the frequency display. Tap that to scroll thru the other connectors.
Napalm
Lake Co, Ind
Having owned 3 different R7000's and at least* 2 different R8500's as well as my current R8600 I have enjoyed all three models. One thing I liked better on the older radios was the ability to easily tap the discriminator for PL/DPL, DTMF and other data decoding with outboard decoders. Otherwise the R8600 runs rings around them as far as feature sets, sensitivity/selectivity and other performance indicators.
The R8600 is the first Icom radio I have ever had new, all the others had been used so that might have something to do with it all. On 2 of my R7000's I had the EEB performance mods done (I know I am dating myself here) and the other I aligned myself. On the R7000 most of the alignments were straight voltage levels when tuned to a specific frequency, no signal generation was needed. With a dozen of so voltage settings the performance was greatly improved.
* I have had 3 R8500's but it might be that one was mine once before as the guy I traded with may have received it from the guy I sold it to.
My 7000 was bought new from EEB in the 90s and it had the scan speed and delay mods as well as the remote control ( The controller was missing ). I like it, I'm a sucker for older Icoms but I am digging the 8600.
ArloG
Also note that as you cross the internal bandpass filter selections below 30 MHz the antenna selections will change.
If you select for example ANT 2 from 1.6 MHz to 2.0 MHZ. The selection made above 2.0 MHz to 6.0 MHZ will change to what you selected for that band. Could be Ant 1,2, or 3. The setting will "stick". It will occur as bandpass filters are internally switched up to 30 MHZ.
I used to have a table showing the different filter ranges. Anyone?
ArloG
Found it in the service manual.
B1 thru B10 should be the thresholds where antenna selections can be made below 30 MHz.
kruser
Well Known Member
W St Louis Cnty, MO
Good point.
Napalm
Lake Co, Ind
My 8600 is being hammered by two (if not more) 2kW FM broadcast transmitters less than 3 miles away. 10dB of attenuation fixes it but holy crap. It's not a huge complaint about the 8600 but does anyone recommend a GOOD FM broadcast filter that doesn't nuke the bottom end (118MHz) of VHF air TOO much?
prcguy
Napalm
Lake Co, Ind
@prcguy specifically but anyone else. I noticed on HF when in the waterfall mode, as I'm tuning using the tuning knob the noise floor increases until I stop tuning. Normal behavior?
ArloG
Familiarization curve. Learning how to use the RF Gain, AFC/AGC, and Reference display settings.
