AR-DV1 ignition noise
Gianpy
good evening. my dv1 due to incorrect feed does not work anymore. when I turn it on, a ticking sound is heard from the audio box. the radio remains locked as if it remained in protection. would it be the voltage regulator? does anyone have the wiring diagram for the power supply? thank you all
marlbrook
Devon, UK
I have seen two other reports re. this. Both seem to have been caused by over voltage being applied, 'blowing' the internal voltage regulator.
One was resolved by the DV1 having to be returned from the U.K. to AOR Japan for repair. They fitted a new regulator.
The other person never reported back.
As far as I am aware AOR have not made circuit diagrams available. Since the returned Unit was sent originally to the main U.K. AOR dealer, who have a repair Department, and they had to send the Radio to AOR, looks like even Main Dealers do not have full circuit details
ChrisP
Portland, OR
Gianpy, have you tried an different external power supply for the DV-1?
I had a similar set of symptoms that were due to a bad external supply. I replaced the power supply and all was fine.
- Chris
Gianpy
- Chris
I tried with various external power supplies. always the same problem
