Importing just a trunked system
seth21w
Somewhere monitoring the air.
Without having conventional frequencies and the whole lot of analog channels. 212 analog channels to delete and i can only select one at a time and delete. you mean i gotta delete each one individually?
03msc
RF is RF
The Natural State
Definitely need more information before someone can adequately answer. Using software? Which software? Also which scanner?
teufler
ST PETERS, MISSOURI
Configuration Settings (EZ Scan)
To access configuration settings, select Settings from
the main menu, and press .
• Default Vals – Restores default settings.
this is the whistler 1095
