Impossible to decode with DSDPlus
SoftSDR
Hello and happy new year!
I've configured SDR# with the antenna and also installed DSDPlus but when I try to decode a signal, nothing happened...
Someone said thats because of W11 ?? Maybe??
Everything is well installed so I asking myself on which part I did something wrong..
I already searched everywhere and found nothing..
If you need more pictures, let me know
Thanks a lot!
r1ccz
Your signal should be visible in the DSD+ Source Audio window. There may be something wrong with your VB Cable settings. Errors are also visible in the DSP interface window.
PDXh0b0
Woodland, WA
in Windows sound manager, under recording tab, set your vb-cable as default output
CanesFan95
Analog already is interoperable.
FL
Instead of using SDR#, try using FMPx.exe. This will also give you trunktracking ability.
dave3825
Suffolk County NY
For starters,
#1 your SDR# is not showing its receiving anything as far as a signal. What the gain set at?
#2 the output level in the DSD interface is maxed out. Usually a quarter and middle is a good place to start.
#3 you also have SDR# outputting audio to the virtual cable, which essentially is what the interface is doing.
Do yourself a favor and use the FMP tuner included with the DSDPlus public and ditch sdr, plug in, and virtual cables.
People who say that are generally clueless and could not get it working themselves. They need somewhere to pass blame, so they blame the OS. Many on here running Windows 11 without issue.
ronenp
The signal on the scope doesnt look like smething that DSDPlus is able to decode
Can you record a audio of the signal as it sound on the SDRSHARP ?
