In need of a USB cable
Bronson24
Frostproof,FL
Hi, I am in need of a USB1 or USB to Serial with Adapter for the scanner ( all I have is the power cord and scanner) for my BCD396T If anyone has a spare laying around an willing to sell it please let me know ASAP I will paypal you the money right over...Thanks alot
post on here or email me at Tysdad2010@hotmail.com
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
You don't need to absolutely have a USB-1 - many common off the shelf models are known to work. We have a few of them listed here, along with some notes about how to use Windows Device Manager to help with loading drivers...
Connecting scanners via USB - The RadioReference Wiki
Just watch out for these el-cheapo models with Prolific chipsets, as mentioned in the article...HTH...Mike
Bronson24
Frostproof,FL
Just watch out for these el-cheapo models with Prolific chipsets, as mentioned in the article...HTH...Mike[/QUOT
See the thing is I dont have the Piece that came with the Scanner ...All I have is the Power cord and scanner...So either someone have a Spare USB1 or another cord that will work for my 396T without me having to order anyhting else for it to work...this programming manually SUCKS!!! i have been programming for 2 days now :( I beleive I have messed up and I want to start over and this time I am not doing it manually lol
kruser
Well Known Member
W St Louis Cnty, MO
nevermind I just ordered the USB1 I cant wait! This is Annoying without a cable :(
Being as you do not have the original cable that came with the scanner that has the special proprietary end on one end, I'd say this was your best move.
As long as you ordered the correct cable, it should have the USB plug on one end and the special mini serial plug on the other end that will plug directly into your 396.
I think some here missed the fact that you do not have the originally supplied cable at all!
From the sounds of your manual programming frustration, I think you will love being able to do it with a computer!
One way to look at it though, you now have manual programming experience which many do not have as they went straight to using a computer. Being able to program the 396 manually is a plus being a portable scanner. You just never know when you may be away from a computer and need to add some things in with the keypad.
I started out in reverse and used a computer from the beginning but I later learned how to do it by hand just in case. Today I find it easy to do it either way. Minus the alpha tags that is. When I do a system by hand, my alpha tags usually end up being a single letter or number! When I can connect the scanner to a computer later, I then change them too something more readable plus save the contents to a file.
EDIT: I looked at the Wiki (from KA3JJZ's link) on the Uniden USB-1 cables and the cable the Wiki links too at Unidens site is NOT the USB-1 cable. It is a link to the original serial to serial cable that was supplied with the scanners. You would still need some type of USB to Serial cable if you purchased that cable if your computer does not have a true serial port on it. The link in the WIki to the USB-1 cable at ScannerMaster does link to the correct USB-1 cable.
For $15 bucks, it may still be worth buying the one that the Wiki links too at Uniden's site though. It never hurts to have the original as it will fit several of the recent Uniden models.
Bronson24
Frostproof,FL
Cool Thanks for everything Kruser...And yes have the upper hand on other people that does not even know where to start on programming manually on the 396 is a plus for me... and when i was doing my alpah tags I was spelling them out LOL that is why it took me almost 2 FULL days to do it LOL...And yes that is what I was trying to tell everyone that I didnt not have the special peice that came with the scanner so I could get the USB to serial...So I just ordered the USB-1 From Uniden came out to $40.64 shipped :( for a freaking USB cable WOW....oh well atleast I will have it and no more manually programming unless I am away from the computer....:)
