Seconded. I ordered the parts when I ran across your original post and it's been a great improvement over everything I had previously tried. Thank you.I'm still using this setup, and it's still working very well.
For those who for whatever reason can't set up an outdoor antenna, this setup works quite a bit better than a ducky/whip.
Antenna:
Stand:
The stand tubing is the exact right size to fit the antenna (35mm OD). The stand needs a minor modification--the plastic caps at the top and bottom need to be removed to allow the coax to feed down inside the stand tubing. The top cap just pulls out, but removing the bottom cap requires removing 3 screws that attach the leg braces to the center column. Unscrew the screws and make sure you collect the nuts from inside the bottom cap, then turn the screws around so the nuts are on the outside instead of the inside to make more room for the coax to come out the bottom. Tighten the nuts finger-tight, and use some loc-tite or super glue to keep them from loosening.
Thread the coax through the column, connect it to the antenna, then set the antenna on the stand, being careful not to pinch the coax as you do so.
The finished project should look something like this:
Yep, it just might "reel" in more signals.This might truly be the dumbest question you've ever been asked: would it work equally well to hang the antenna from the ceiling using some plastic fishing line?
Is that frigin duct tape ?!?! You need a few bucks to buy a cheap U-bracket so I no longer have to look that that hideous thing ? I'll paypal it to you just so my eyes don't bleed anymore !
What kind of coax and ends are required for this to connect to my 325P2?For those who for whatever reason can't set up an outdoor antenna, this setup works quite a bit better than a ducky/whip.
Antenna:
Stand:
I'm using LMR400, with a short pigtail of smaller coax for stress relief going into my multicoupler, and a t-stub filter to notch out the cellular band.What kind of coax and ends are required for this to connect to my 325P2?
