Input For LTR
kpoe_28
Kennett Missouri
The base is weak. The modulation is real low and it sounds like the "motor boat" in the background anytime the mic is keyed. I don't know how since it's not supposed to be digital.
Hey there zz, The base is not getting into the system very good because the antenna for the LTR system up at dispatch which is a 4 element beam antenna is pointing down, It got out of adjustment when we had the ice storm, and your on the backside of the beam so I don't think you'll hear them all that great if you try to listen to the base's TX freq,( the repeater input freq )
zzdiesel
Kennett / Dunklin Co, Mo.
Thanks again, Kevin. I'll have to stop in to talk to my son the CO again soon and look over the antenna system. I have really never took time to see how it all looks since they put in the LTR system.
btritch
Are they still using VHF 154.385 and 155.535 for Sheriff's Department Comms too or is it all 100% UHF LTR Battles Communications System Now?
I can hear the VHF channels here but can't hear the Steele Site of the UHF LTR System.
zzdiesel
Yes Brian, Those two you listed are still the two main channels for our county. They are the privately owned north end and south end repeaters. The Battles Steele tower is about the only LTR system they are using. I understand that there is yet a lot of antenna damage & etc to be repaired from this past January's ice storm. I don't what is going on with the Warner Tower in Campell that is used mostly by Campbell PD. I can hear both their base and the mobiles just fine but they can't hear each other at all.
